Inno3D iChill GeForce GTX 275 Review
Written by Harry Butler
July 15, 2009 | 00:05
Tags: #12 #aftermarket-cooler #gtx-275 #ichill #performance #review #tested
Companies: #arctic-cooling #inno3d
Power Consumption (Idle and Gaming)
We tested the power consumption with a Watts Up? Pro power meter, using the device to record the total system power consumption at the wall socket, while we ran three sets of four runs of Crysis in DX10 at 1,920 x 1,200.
Using the data recorded by the meter we could determine the peak output, the consistent minimum and the average load over the entire run of tests.
As both ATI and Nvidia test benches are now identical Core i7 systems, we can accurately determine the apples to apples difference of what power both PCs take to run.
Power Consumption (idle)
Windows Vista Desktop (Aero Enabled)
  • Nvidia GeForce GTX 275 896MB
  • Inno3D iChill GeForce GTX 275 896MB
  • Nvidia GeForce GTX 285 1GB
  • ATI Radeon HD 4870 1GB
  • Sapphire Radeon HD 4890 1GB Atomic
  • ATI Radeon HD 4890 1GB
    • 167
    • 188
    • 196
    • 208
    • 215
    • 222
100
150
200
250
Power at socket (W)
  • Power Consumption (W)
The iChill's idle power consumption is strangely a good 20W in excess of the the stock GTX 275, which is certainly a weird result considering the GTX 275's excellent low-power mode. This difference then is likely down to differences between individual GPUs rather than the iChill being particularly thirsty as three fans don't make much more difference than one.
Power Consumption (peak)
Crysis DX10 at 1,920 x 1,200 0xAA 16xAF, Peak Power Usage
    • 282
    • 317
    • 339
    • 350
    • 364
    • 365
200
300
400
Power at socket (W)
The same seems to be the case when looking at the card's load power consumption, where the iChill we've tested pulls a clear 14W less than a stock GTX 275 under identical Crysis gameplay circumstances.
